[phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4602: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4604: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4605: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765) [phpBB Debug] PHP Warning: in file /includes/functions.php on line 4606: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765) Fiat 125p • Zobacz wątek - Fiat 125p 2.0 DOHC Lampredi Motore
elektryczną pompę paliwa montuje się jak najbliżej zbiornika paliwa
Fiat elegancki
Re: Fiat 125p 2.0 DOHC Lampredi Motore
Napisane: 27 maja 2013, o 17:43
przez Tomek1985
Powiem szczerze nie mam problemu z tą pompa która jest zamontowana pod maska. Jedyne co dałem przed pompą to zaworek żeby ewentualnie paliwo się nie cofało . Na jednym gaźniku odpala mi za pierwszym razem natomiast na dwóch za drugim (taki ich urok)
Napisane: 29 cze 2013, o 12:38
przez Tomek1985
Czas mija i mija ale coś się jednak dzieje
Porobiłem parę dupereli, udało mi się zdobyć fajne pióra wycieraczek oraz co najważniejsze odebrałem gaźniki od małej regenercji
Wymiana oleju na coś świeżego
Oraz deser
Oraz daję na prośbę Kanciastego parę filmów Może to nie Hollywood ale zawsze coś
I to jest TO! Pięknie brzmi. Długo czekałem i się doczekałem Ile mocy mogłeś zyskać poprzez założenie dwóch gaźników?
Napisane: 29 cze 2013, o 21:22
przez Tomek1985
Faktycznie dźwięk gaźników jest miluni dla ucha, nie mówiąc o tym, że osiągi też poszły do przodu
Gość który regenerował mi gaźniki powiedział, że Fiacior powinien dostać ok 20% mocy więcej ale tak naprawdę do jedynie wyjazd na hamownie coś wykarze
Napisane: 30 cze 2013, o 11:08
przez narkee
Ładnie drze japę!
Napisane: 13 kwi 2014, o 14:14
przez Tomek1985
Małe odkurzenie tematu. Sezon rozpoczęty a wraz z nim coś trzeba przy autku porobić.
Musiałem wywieźć trochę płytek z mieszkania i sprawdziłem jak wygląda Fiacior na lekkiej 5cm glebie z tyłu. Przód był robiony 3 lata temu i jego stan się nie zmieni, tył może dupy nie urywa ale mi tak się podoba i tak zostanie. Linia nadwozia (przód-tył) wyrównała się:D Tak jak pisałem to był tylko test na jego wygląd, natomiast w tej chwili jestem w trakcie zamawiania nowych resorów sklepanych i z dodatkowym piórem, wymieniam wszystkie śruby na nowe , tuleje poliuretanowe plus most napewno w jakimś kolorze.
Z tyłu zmieni się końcówa wydechu bo teraz przypomina tłumik z poloneza a to jest tłumik środkowy przelotowy z Golfa Gti.
Napisane: 14 kwi 2014, o 09:22
przez Giwera
Piękny jest Co to są za lusterka ??
Napisane: 14 kwi 2014, o 13:34
przez Tomek1985
Lusterka to Bullety dedykowane ogólnie do Garbusa ale w paru Fiatach je w[*]idziałem wcześniej zanim swoje kupiłem i bardzo mi się spodobały. Minus jest taki ,że mają małe pole widzenia ale idzie się przyzwyczaić:). Są w ofercie na stronie Garbusy.pl
Napisane: 15 kwi 2014, o 00:38
przez Giwera
O dzięki wielkie też bardzo mi się spodobały nadają klimatu muscle-car
Napisane: 16 kwi 2014, o 14:50
przez Grzechu
No powiem Ci Panie... ładnie to to jeździ
Napisane: 21 kwi 2014, o 15:36
przez Stuart
Taki Fiat może zaskoczyć na światłach. Silnik nieźle gra, a auto wygląda rasowo. Tylko pogratulować
